Hi everybody,
I am looking for a template for monitor SAN switches in our environment. They are brocade and I want to get items through snmp v3. I searched at share.zabbix.com but I could not find detailed template which created for snmp v3. I also use zabbix 4.0 fyi. First question is do you use any template for brocade san switches and use snmp v3 which takes most of metrics form switch? Second question is do you think does it work that if I merge simple template for brocade san sw (using snmp v3) and detailed template for same product (using snmp v2) that I found? The way to merge that in my mind is use snmp v3 template and add missing oids from detailed snmp v2 template to simple template xml file.
Thanks in advance.
Thanks in advance.
