Zabbix 4.4. with several alerts: "Disk read/write request responses are too high"
  • robertitox
    • Sep 2020
    Dear all, I have a Zabbix 4.4 platform: one Frontend server, another DB (Mafriadb) server and the Zabbix server. All these 3 servers run on vmware hosts which a storage behind.
    Everything looks good, except for the alarms telling:
    Disk read/write request responses are too high (read > 20 ms for 15m or write > 20 ms for 15m)
    This alarms are fired for several Linux hosts with Zabbix agents.
    I have lot of RAM and CPU's, the load is OK.
    My zabbix_server.conf is:
    ListenPort=10051
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=0
    PidFile=/var/run/zabbix/zabbix_server.pid
    SocketDir=/var/run/zabbix
    DBHost=10.32.88.100
    DBName=zabbix
    DBUser=zabbix
    DBPassword=xxx
    DBPort=3306
    StartPollers=20
    StartPollersUnreachable=10
    StartPingers=10
    VMwareCacheSize=64M
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    StartDBSyncers=10
    Timeout=30
    UnreachablePeriod=60
    UnreachableDelay=20
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    FpingLocation=/usr/bin/fping
    Fping6Location=/usr/bin/fping6
    LogSlowQueries=3000
    StatsAllowedIP=127.0.0.1
    In frontend and DB nodesI have not done any customized configuration, everything by default.
    Can you help me please???
    Maybe my VMware storage is running abnormally???
    Special thanks!!!
  • LenR
    • Sep 2009
    • 1011
    So these alerts are NOT you your zabbix server, just "random" other Linux hosts? If so, it's pointing to potential I/O issues on these hosts. On a new install, using the supplied templates, these values are just "suggestions" from the install. If these levels don't fit your environment, then adjust the template, or make rules for "I/O Slow" systems. However, that is pretty bad I/O response.
