Returned values from system.run script? Can they be referenced in Operations?
  • jmrice
    • Aug 2019
    • 33
    #31
    I could try something like:
    {zabbix.mydomain.com:system.run[/usr/local/bin/checkissuer.sh mydomain.com 443].strlen()}>0
    But the actual string value might not be available, just the number of characters.
    Then, what would {{HOST.HOST}:{ITEM.KEY2}.last()} evaluate to be?
    • tim.mooney
      • Dec 2012
      • 1430
      #32
      I think in that case (if you have to use .strlen()>0 in the trigger) using {ITEM.KEY2}.last() is the correct thing to do. Give it a try.
      • jmrice
        • Aug 2019
        • 33
        #33
        Interesting tidbit from the docs:
        https://www.zabbix.com/documentation...ers/expression
        Functions
        Trigger functions allow to reference the collected values, current time and other factors.
        A complete list of supported functions is available.
        All functions return numeric values only. String comparison is not supported.
        If you want string comparison, upgrade to Zabbix 5.0. <<<<<<<<<<<<<<<<<<<<< !!!
        https://www.zabbix.com/documentation...ers/expression (5.0)
        Functions
        Typically functions return numeric values.
        However, returning strings for string comparison is also possible with = and <> operators;
        see operators and trigger examples for more details.
        Although, I didn't find string comparisons to be possible. We are currently running 5.0
        • jmrice
          • Aug 2019
          • 33
          #34
          Good news!
          Testing: SSL Certificate from Let's Encrypt on zabbix.mydomain.com expires in 30 days !
          Thank you!
          • tim.mooney
            • Dec 2012
            • 1430
            #35
            Originally posted by jmrice
            Good news!
            Excellent. To help out the next person, will you post both the trigger expression you ended up using and the message template from the message?
            • jmrice
              • Aug 2019
              • 33
              #36
              Trigger expression:
              {zabbix.mydomain.com:system.run[/usr/local/bin/checkssl.sh mydomain.com 443].last()}<=90 and
              Operations message:
              Problem name: {EVENT.NAME}
              Severity: {EVENT.SEVERITY}
              SSL Certificate from {ITEM.VALUE2} expires in {ITEM.VALUE1} days !
              • jmrice
                • Aug 2019
                • 33
                #37
                For those that are curious, I found the checkssl.sh script at: https://medium.com/@sean_bradley/mon...x-860279519238
                I modified that to make the checkissuer.sh script:
                data=`echo | openssl s_client -servername $1 -connect $1:$2 2>/dev/null | openssl x509 -noout -issuer | grep -oP '^.*O=\K(.*?)(?:\/)' | awk -F/ '{print $1}'`
                echo $data
