Monitoring log with custom name format
  • TrapoSAMA
    • Aug 2020
    • 16
    Hi!
    Is possible and how check a log with name and ubication like /folder1/folder2/month-year/log-day-month-year, the log change the name when day is finish.
    Thx.
  • isaqueprofeta
    • Aug 2020
    • 154
    Review logrt agent key, you can set up a custom regexp for the rotation pattern of your logfile: https://www.zabbix.com/documentation...s/zabbix_agent
    • TrapoSAMA
      • Aug 2020
      • 16
      Hi!
      i try but i dont know why to use. Examples are simple and dont find how to use with format like day or month or year or today.
      Do you have some examples?
      Thx
      • isaqueprofeta
        • Aug 2020
        • 154
        It's inside the Docs that I send on the link before...
        Examples:
        ⇒ logrt["/home/zabbix/logs/^logfile[0-9]{1,3}$",,,100] → will match a file like "logfile1" (will not match ".logfile1")
        ⇒ logrt["/home/user/^logfile_.*_[0-9]{1,3}$","pattern_to_match","UTF-8",100] → will collect data from files such "logfile_abc_1" or "logfile__001".
        • TrapoSAMA
          • Aug 2020
          • 16
          Hi!
          but the log structure is /var/log/2020-09/2020-09-08.log <- this is for today, the log change tomorrow and the previuos log cant be deleted, idel for the previous folder.
          Do you have a example for this type of pattern log ?
          Thx
          • isaqueprofeta
            • Aug 2020
            • 154
            Hi!
            Thx
            For your specific case no. But there's a lot of examples to study, in official Docs: https://www.zabbix.com/documentation...sions#examples
            • Hamardaban
              • May 2019
              • 2714
              You initially incorrectly formulated your question - you change not only the file name, but also the path to the file.
              zabbix doesn't work that way.
              • Regular expressions for logrt are supported in filename only, directory regular expression matching is not supported.
              • TrapoSAMA
                • Aug 2020
                • 16
                Hi!
                If is only for the log name, how to identified one log with the today day format?
                Thx
                • Hamardaban
                  • May 2019
                  • 2714
                  “^/var/log/2020-09/\d{4}-\d{2}-\d{2}.log$“
                  • jurgen16
                    • Jul 2023
                    • 13
                    What about for log file that are like this
                    /var/log/containers/container_name_fdsdjkfasdfads5f4s6dfsda65f.log and the way I tried to catch this kind of file log is like this but didn't worked for me: /var/log/containers/container_name_\w{26}.log$
                      "\/var\/log\/containers\/container_name_\w{27}.log$"
                      Explore and test this PCRE2 (PHP) regular expression online. Understand the pattern with regex explanations, generate code, and export matches to CSV or JSON.
