using ldaps with zabbix
  • heba
    • Jan 2020
    • 40
    Dear All,
    Is it possible to use ldaps for zabbix authentication ?
    If yes, how to import certificate of the active directory to zabbix ?
    Heba
  • halldorg
    • Sep 2020
    What I needed to do was to get the certificate via openssl s_client -connect dc.example.com:636 -showcerts
    then check /etc/ldap/ldap.conf for where the certificates are stored
    Then add the certficates from the DC to that file.
    After that I could successfully use ldaps://dc.example.com:636 as ldap server and port as 636
    • heba
      • Jan 2020
      • 40
      Many Thanks Halldrog.
      Can you please paste example contents from your /etc/ldap/ldap.conf
      Heba
      • srb
        • Sep 2020
        • 10
        Depending on your version of Zabbix, we simply did the following:
        • Browsed to "Administration, Authentication"
        • Configured LDAPS settings in the tab "LDAP Settings"
        • Configured "Authentication" to use LDAP
        • Created a new user account without a password
        • On CentOs 7 we imported the Root CA certificate (PEM format if I recall correctly) into the ca-bundle by placing the Root cert in the "/etc/pki/ca-trust/source/anchors/" directory and ran the command "update-ca-trust enable"
        Can't recall if those were all the steps, but should help you get closer
        • halldorg
          • Sep 2020
          TLS_CACERT /etc/ssl/certs/ca-certificates.crt
          TLS_REQCERT never
          Then the file /etc/ssl/certs/ca-certificates.crt will contain the certificates
          • LenR
            • Sep 2009
            • 1011
            It seems to be magical to include the port number in the ldaps url as above. I've had problems if that is left off, it doesn't seem to honor the port field.
            • heba
              • Jan 2020
              • 40
              Many Thanks Halldrog. it works
              • Liroys27
                • Sep 2022
                Hi, we are using k8s deployment with zabbix-server and zabbix-web pods inside using the latest image of:
                zabbix server:
                zabbix/zabbix-server-mysql:ubuntu-6.2.2
                zabbix web:
                zabbix/zabbix-web-nginx-mysql:ubuntu-6.2.2
                I tried to go through the pod and look for /etc/ldap/ldap.conf but I don't see anything there. is there another path using this pod for importing root.ca for our domain?
