remote commands not supported
  • rumpel1984
    • Feb 2015
    I am getting the following in my zabbix-server logs "item "zabbix-proxy1:system.run[cat /etc/issue]" became not supported: Remote commands are not enabled."
    Even though, my configuration on the zabbix-proxy1 host is as follows:
    [root@zabbix-proxy1 ~]# egrep -v "^#" /etc/zabbix/zabbix_agentd.conf | sed '/^$/d'
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    LogFile=/var/log/zabbix/zabbix_agentd.log
    LogFileSize=0
    Server=192.168.4.5
    StartAgents=3
    ServerActive=192.168.4.5
    Hostname=zabbix-proxy1
    Include=/etc/zabbix/zabbix_agentd.d/
    EnableRemoteCommands=1
    My agent has been restarted since setting this value. Does anyone know what I need to check to make sure this kind of check can work?
    Thanks!
