database upgrade 3.0.x to 4.4 Mysql errors
  • klarter
    • Jul 2020
    • 27
    Initial try at upgrade caused SQL errors.
    Manually dropped several tables
    Finally, I am stuck here:
    [Z3005] query failed: [1005] Can't create table `zabbix`.`corr_condition_tag` (errno: 150 "Foreign key constraint is incorrectly formed") [alter table `corr_condition_tag` add constraint c_corr_condition_tag_1 foreign key (`corr_conditionid`) references `corr_condition` (`corr_conditionid`) on delete cascade]
  • klarter
    • Jul 2020
    • 27
    Finally a good restore of the old database. Now I am back to first error message I got trying to upgrade. Which is:
    Can't drop FOREIGN KEY 'c_sessions_1'
    • klarter
      • Jul 2020
      • 27
      The old db has no such foreign key. Show create table for sessions is:
      CREATE TABLE `sessions` (
      `sessionid` varchar(32) COLLATE utf8_bin NOT NULL DEFAULT '',
      `userid` bigint(20) unsigned NOT NULL,
      `lastaccess` int(11) NOT NULL DEFAULT 0,
      `status` int(11) NOT NULL DEFAULT 0,
      PRIMARY KEY (`sessionid`),
      KEY `sessions_1` (`userid`,`status`)
      ) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_bin |
      • tim.mooney
        • Dec 2012
        • 1436
        Did you start using Zabbix at an earlier version, and upgrade it (possibly multiple times) to get to 3.0?
        I've posted on these forums before about some of the things I did to "clean up" schema inconsistencies in my Zabbix database to prepare for Zabbix 5.x. One of the threads with links to some of the posts is here: https://www.zabbix.com/forum/zabbix-...ariadb-upgrade
        • klarter
          • Jul 2020
          • 27
          Thanks, Tim
          Started with brand new zabbix 3.0 in August, this year. No manual changes made.
          Looks like a difficult process ahead.
