i have lots of zabbix clients, but i have this annoying issue on few of them
after reboot the agent fails to start:
service zabbix-agent status
● zabbix-agent.service - Zabbix Agent
Loaded: loaded (/lib/systemd/system/zabbix-agent.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2020-09-13 11:49:48 IDT; 3s ago
Docs: man:zabbix_agentd
Process: 26552 ExecStart=/usr/sbin/zabbix_agentd --foreground (code=exited, status=1/FAILURE)
Main PID: 26552 (code=exited, status=1/FAILURE)
Sep 13 11:49:48 dev5 systemd[1]: Started Zabbix Agent.
Sep 13 11:49:48 dev5 zabbix_agentd[26552]: zabbix_agentd [26552]: cannot create PID file [/var/run/zabbix/zabbix_agentd.pid]: [2] N
Sep 13 11:49:48 dev5 systemd[1]: zabbix-agent.service: Main process exited, code=exited, status=1/FAILURE
Sep 13 11:49:48 dev5 systemd[1]: zabbix-agent.service: Failed with result 'exit-code'.
if i create the folder under zabbix:zabbix
and start service again it works (until next reboot)
