Configuration>Triggers - Any way to filter/not all triggers show up!
  • HaveDill
    • Sep 2014
    • 103
    My low level discovery created roughly 3600 triggers for some of our switches.
    The main ones i want to copy/edit are high severity, but even the sort by severity does not work. Because it only loads up 1000 triggers and hides the rest!!
    I've tried ZBXNEXT 221 patches, but they all fail. Can someone please help me get a better filter setup, or at least figure out a way i can see ALL my triggers???
  • HaveDill
    • Sep 2014
    • 103
    RESOLVED.
    From ZBXNEXT 221 the 0001-pidzero patch DID work successfully.
    For those who had issues finding a command for that shit, it was this:
    sudo patch -p0 < 0001-pidzero-s-trigger-filtering-ZBXNEXT-221.patch
    I had to manually enter the files it was supposed to patch though.
