Create two items for the same key
  • moshikoy
    • Aug 2017
    • 56
    I'd like to have a certain discovery key to have 2 metrics,
    1. cumulative
    2. change
    sampling the item gives me the cumulative value
    I'd like to have another item for that same key with Preprocessing - simple change
    How can I achieve that? since using the same item is not possible
    Thanks,
    - Moshe
  • eithor
    • May 2020
    • 50
    You create a "dependent" item and point it to the other item.
    • moshikoy
      • Aug 2017
      • 56
      Thanks!!
      Solved
