Autoregistration actions - Host name matches won't match regex or string
  • LaChagnasse
    • Sep 2020
    Hi everyone,
    I'm trying to do a simple thing yet can't manage to do it. We use regex all over zabbix but i can't get my autoregistration rule to work :
    Click image for larger version  Name:	Capture.JPG Views:	22 Size:	32.9 KB ID:	409172
    I tried every regex i thought of, ^.*replic.*sc.*$ /.*replic.*sc.*/i replic.*sc
    I'm testing with an host which host name is test-REPLic-Sc-test
    We have a lot of old and new naming conventions so i want it to be case insensitive and if it matches, to add the host to a group and a template. It's currently working if i use "CONTAINS" instead of "MATCHES", but i have to specify each case with OR calculation and i can't do this for every actions...
    I have another action which add the host to zabbix just fine.
    Documentation isn't helping and i know it should work it has been implemented
    Any help will be very much appreciated
  • LaChagnasse
    • Sep 2020
    Guess i don't know regex as much as i thought, it was a stupid regex issue. (?i) -> usual flag /i
