Templates after upgrade
  • Halloween_BE
    • Oct 2019
    • 26
    I have installed a Zabbix 4 a year ago. I have around 100 templates in it coming from the fresh install.
    I have upgraded this server to version 5 a few weeks ago and it's running well but I see on a fresh version 5 install more templates than I have in my upgraded version.
    Is it normal ?
    On the fresh v5 I have more items on a Windows OS template than on my v5 upgraded...
    How can I do to install the missing templates?
    Regards
  • tim.mooney
    • Dec 2012
    • 1436
    Is it normal ?
    That is completely normal.
    The upgrade process does not automatically upgrade or change any templates in your environment. The reason is that if you customized any of the predefined templates that came with your previous version, you would lose those customizations if they were automatically changed by the upgrade process.
    The Zabbix documentation chapter on Installation (chapter 4) has a section on Upgrades and then a later section on templates. How to update your templates is covered in that section: https://www.zabbix.com/documentation...mplate_changes
    • Halloween_BE
      • Oct 2019
      • 26
      Thanks for this reply. I will check this doc.
      Regards
