hey i'm really new in zabbix and vsphere, so i wanna monitoring my vcenter and i should config macro in zabbix frontend, right? my question is.. i should fill {$URL} url with /sdk, do i just fill https://server_name/sdk or i should config something before that? like you know when i googling sdk it will appears many type of sdk and i confused..
how to fill url sdk
Tags: None
Try to read and understand.
https://blog.zabbix.com/zabbix-2-4-f...nitoring/3675/
If you don't understand, use the Internet search.
