zabbix 5.02 get "404 Not found" after i install Centos Web panel
  • haiha298
    • Sep 2020
    Hi all, after i install CWP7, i can not access my zabbix via web
    Get error:
    Not Found
    The requested URL /zabbix/ was not found on this server.
    systemctl status zabbix-server
    ● zabbix-server.service - Zabbix Server
    Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor preset: disabled)
    Active: active (running) since Fri 2020-09-18 09:54:33 +07; 1h 1min ago
    Main PID: 45428 (zabbix_server)
    Tasks: 40 (limit: 11333)
    Memory: 129.0M
    CGroup: /system.slice/zabbix-server.service
    ├─45428 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
    ├─45430 /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.164312 sec, idle 60 sec]
    ├─45431 /usr/sbin/zabbix_server: housekeeper [deleted 0 hist/trends, 0 items/triggers, 0 events, 0 sessions, 0 alarms, 0 audit items, 0 records i>
    ├─45432 /usr/sbin/zabbix_server: timer #1 [updated 0 hosts, suppressed 0 events in 0.000356 sec, idle 59 sec]
    ├─45433 /usr/sbin/zabbix_server: http poller #1 [got 0 values in 0.000536 sec, idle 5 sec]
    ├─45434 /usr/sbin/zabbix_server: discoverer #1 [processed 0 rules in 0.000378 sec, idle 60 sec]
    ├─45435 /usr/sbin/zabbix_server: history syncer #1 [processed 5 values, 5 triggers in 0.001252 sec, idle 1 sec]
    ├─45436 /usr/sbin/zabbix_server: history syncer #2 [processed 0 values, 0 triggers in 0.000018 sec, idle 1 sec]
    ├─45437 /usr/sbin/zabbix_server: history syncer #3 [processed 0 values, 0 triggers in 0.000029 sec, idle 1 sec]
    ├─45438 /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, idle 1 sec]
    ├─45439 /usr/sbin/zabbix_server: escalator #1 [processed 0 escalations in 0.000690 sec, idle 3 sec]
    ├─45440 /usr/sbin/zabbix_server: proxy poller #1 [exchanged data with 0 proxies in 0.000032 sec, idle 5 sec]
    ├─45441 /usr/sbin/zabbix_server: self-monitoring [processed data in 0.000017 sec, idle 1 sec]
    ├─45442 /usr/sbin/zabbix_server: task manager [processed 0 task(s) in 0.000355 sec, idle 5 sec]
    ├─45443 /usr/sbin/zabbix_server: poller #1 [got 1 values in 0.001971 sec, idle 1 sec]
    ├─45444 /usr/sbin/zabbix_server: poller #2 [got 0 values in 0.000031 sec, idle 1 sec]
    ├─45445 /usr/sbin/zabbix_server: poller #3 [got 10 values in 0.006553 sec, idle 1 sec]
    ├─45446 /usr/sbin/zabbix_server: poller #4 [got 2 values in 0.001626 sec, idle 1 sec]
    ├─45447 /usr/sbin/zabbix_server: poller #5 [got 1 values in 0.001566 sec, idle 1 sec]
    ├─45448 /usr/sbin/zabbix_server: unreachable poller #1 [got 0 values in 0.000029 sec, idle 5 sec]
    ├─45449 /usr/sbin/zabbix_server: trapper #1 [processed data in 0.032754 sec, waiting for connection]
    ├─45450 /usr/sbin/zabbix_server: trapper #2 [processed data in 0.001330 sec, waiting for connection]
    ├─45451 /usr/sbin/zabbix_server: trapper #3 [processed data in 0.031872 sec, waiting for connection]
    ├─45452 /usr/sbin/zabbix_server: trapper #4 [processed data in 0.048425 sec, waiting for connection]
    ├─45453 /usr/sbin/zabbix_server: trapper #5 [processed data in 0.037452 sec, waiting for connection]
    ├─45454 /usr/sbin/zabbix_server: icmp pinger #1 [pinging hosts]
    ├─45455 /usr/sbin/zabbix_server: alert manager #1 [sent 0, failed 0 alerts, idle 5.003259 sec during 5.003351 sec]
    ├─45456 /usr/sbin/zabbix_server: alerter #1 started
    ├─45457 /usr/sbin/zabbix_server: alerter #2 started
    ├─45458 /usr/sbin/zabbix_server: alerter #3 started
    ├─45459 /usr/sbin/zabbix_server: preprocessing manager #1 [queued 0, processed 35 values, idle 5.007818 sec during 5.008106 sec]
    ├─45460 /usr/sbin/zabbix_server: preprocessing worker #1 started
    ├─45461 /usr/sbin/zabbix_server: preprocessing worker #2 started
    ├─45462 /usr/sbin/zabbix_server: preprocessing worker #3 started
    ├─45463 /usr/sbin/zabbix_server: lld manager #1 [processed 1 LLD rules during 5.014930 sec]
    ├─45464 /usr/sbin/zabbix_server: lld worker #1 [processed 4 LLD rules, idle 53.188515 sec during 53.223922 sec]
    ├─45465 /usr/sbin/zabbix_server: lld worker #2 [processed 4 LLD rules, idle 54.090238 sec during 54.115931 sec]
    ├─45466 /usr/sbin/zabbix_server: alert syncer [queued 0 alerts(s), flushed 0 result(s) in 0.000528 sec, idle 1 sec]
    ├─52644 sh -c /usr/sbin/fping -C3 -i0 2>&1 </tmp/zabbix_server_45454.pinger;
    └─52645 /usr/sbin/fping -C3 -i0
    Sep 18 09:54:33 centos8.sin.com systemd[1]: Stopped Zabbix Server.
    Sep 18 09:54:33 centos8.sin.com systemd[1]: Starting Zabbix Server...
    Sep 18 09:54:33 centos8.sin.com systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file >
    Sep 18 09:54:33 centos8.sin.com systemd[1]: Started Zabbix Server.
  • haiha298
    • Sep 2020
    can you help me or leave some issues?
    • tim.mooney
      • Dec 2012
      • 1430
      The Zabbix web interface (the "web frontend") is separate from the zabbix-server. In a large environment you might even install the web front end on a completely separate server from the 'zabbix-server' process.
      The 'zabbix-server' process can be running (and functioning correctly) even when the web front end is broken.
      You broke the Zabbix web front end (only, not the zabbix-server) when you installed the "CentOS Web panel". The CentOS Web panel software probably modified your web server configuration, and whatever modifications it put in place are interfering with the web server configuration that's needed for the zabbix web front end.
      If you need to have the Centos Web panel and the Zabbix web front end both working on the same server, you will need to examine your web server configuration and make adjustments to the web server configuration.
      • haiha298
        • Sep 2020
        tim.mooney Thank you for give an issues. CWP install another apache have path usr/local/apache, so i copy my zabbix.conf to /usr/local/apache/conf.d/ now i get this error
        503 Service Unavailable
        The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
        how can i fix it?
