Weird Parameter Behavior on Zabbix API
  • artrune
    • Aug 2020
    • 16
    Hello! Hope you are doing well.
    I've encountered something weird while testing the host.get method on the zabbix api, the selectItems parameter doesnt seem to work (It only works if i use extend, but I just want one property and not the whole output)
        "jsonrpc": "2.0",
        "method": "host.get",
        "params": {
                    "output": ["hostid","name"],
                    "selectItems": "itemid",
                    "selectParentTemplates": ["templateId", "name"],
                    "selectGroups": "groupid"
        "auth": "xxxx",
        "id": 1
    Any clues, or ideas? The other selects do run fine.
    Running Zabbix 5.0.2
  • artrune
    • Aug 2020
    • 16
    Turns out if i modify the select to
     "selectItems": ["itemid", "key_"],
    It then works.
