Zabbix and Health Checks of Server Hardware
  • gglea
    • Mar 2015
    How (if possible) would zabbix handle health checks of server hardware such as cpu, raid volumes, power supply etc without using SNMP traps? Is there a way for zabbix to pull these checks from the devices using the zabbix agent in order to for example show predictability of a hard disk failing? Is there a way it can work with Dell Openmanage to pull this information? Any info regarding this would be appreciated.
  • HaveDill
    • Sep 2014
    • 103
    For my HP servers i found a nagios vbs script that runs and reports back RAID status' using HPAcucli
    So in each of my C:\Zabbix folder i put in the .vbs, then in the agentd.conf i placed the custom key i want for this script:
    UserParameter = smartarray,cscript "C:\Zabbix\check_smartarray.vbs"
    Then in my Zabbix host i have an item that points to that key, and checks once a day on my RAID status'. Triggers check for regular expressions in the returned value.
    Part of my powershell rollout script also made shure that HPACUCLI existed on the remote machine (we are an HP house), and if not copied the proper files over so the vbs would run successfully.
    • aib
      • Jan 2014
      • 1615
      There are my five cents about RAID control:
      zabbix_agentd.conf
      UserParameter=raid.ad,sh /usr/lib/zabbix/externalscripts/aacraid.active_drives
      UserParameter=raid.cs,sh /usr/lib/zabbix/externalscripts/aacraid.controller_status
      UserParameter=raid.ld,sh /usr/lib/zabbix/externalscripts/aacraid.LD_status $1
      # cat aacraid.active_drives
      #!/bin/sh
      sudo /usr/local/sbin/arcconf getconfig 1 PD | grep "State" | grep "Online"| wc -l
      # cat aacraid.controller_status
      #!/bin/sh
      sudo /usr/local/sbin/arcconf getconfig 1 AD  | grep "Controller Status" | grep -vc Optimal
      # cat aacraid.LD_status
      #!/bin/sh
      sudo /usr/local/sbin/arcconf getconfig 1 LD $1 | grep device | grep -v information
      # arcconf getconfig 1 AD
      Controllers found: 1
      Controller information
         Controller Status                        : Optimal
         Channel description                      : SATA
         Controller Model                         : Adaptec 2810SA
         Controller Serial Number                 : C80489
         Physical Slot                            : 6
         Installed memory                         : 64 MB
         Copyback                                 : Disabled
         Background consistency check             : Enabled
         Automatic Failover                       : Enabled
         Stayawake period                         : Disabled
         Spinup limit internal drives             : 0
         Spinup limit external drives             : 0
         Defunct disk drive count                 : 0
         Logical devices/Failed/Degraded          : 3/0/0
         Controller Version Information
         BIOS                                     : 4.2-0 (8205)
         Firmware                                 : 4.2-0 (8205)
         Driver                                   : 1.2-0 (30300)
         Boot Flash                               : 0.0-0 (0)
         Controller Battery Information
         Status                                   : Not Installed
      Command completed successfully.
      Sincerely yours,
      Aleksey
      • aib
        • Jan 2014
        • 1615
        and one more - about CPU temperature:
        zabbix_agentd.conf:
        UserParameter=cpu.temp[*],/usr/lib/zabbix/externalscripts/cpu_t $1
        [B]# cat /usr/lib/zabbix/externalscripts/cpu_t[/B]
        #!/bin/bash
        echo $(date '+%Y%m%d:%H%M%S') $0 $1 =\> `/usr/bin/sensors | grep temp` >> /var/log/zabbix/cpu_t.log
        v=$(/usr/bin/sensors | awk -v k=$1 ' /'temp'/ {
        if (k == "current")
        { split($2,a,".")
        split(a[1],b,"+")
        else
        if (k == "high")
        { split($5,a,".")
        split(a[1],b,"+")
        END {print b[2]}')
        echo $(date '+%Y%m%d:%H%M%S') $0 $1 =\> $v >> /var/log/zabbix/cpu_t.log
        echo $v
        [B]# /usr/bin/sensors[/B]
        w83627hf-isa-0290
        Adapter: ISA adapter
        in0:         +1.46 V  (min =  +1.25 V, max =  +1.86 V)
        in1:         +3.33 V  (min =  +2.80 V, max =  +3.79 V)
        in2:         +3.31 V  (min =  +2.80 V, max =  +3.79 V)
        in3:         +2.93 V  (min =  +2.53 V, max =  +3.42 V)
        in4:         +3.15 V  (min =  +2.67 V, max =  +3.62 V)
        in5:         +0.66 V  (min =  +0.30 V, max =  +0.99 V)
        in6:         +1.78 V  (min =  +1.52 V, max =  +2.06 V)
        in7:         +3.23 V  (min =  +0.54 V, max =  +3.23 V)
        in8:         +1.17 V  (min =  +0.05 V, max =  +2.37 V)
        fan1:       5192 RPM  (min = 1424 RPM, div = 4)
        fan2:       5037 RPM  (min = 1424 RPM, div = 4)
        fan3:          0 RPM  (min = 1424 RPM, div = 4)  ALARM
        temp1:       +27.0°C  (high = +65.0°C, hyst = +60.0°C)  sensor = thermistor
        temp2:       +28.0°C  (high = +75.0°C, hyst = +70.0°C)  sensor = thermistor
        temp3:       +28.5°C  (high = +75.0°C, hyst = +70.0°C)  sensor = thermistor
        cpu0_vid:   +1.500 V
        beep_enable:enabled
        Sincerely yours,
        Aleksey
        • Raged23
          • Mar 2015
          Openmange Dell Server - Windows
          I use the same method as HaveDrill in a Windows enviroment.
          This allows you to use an Active Agent behind firewalls.
          With Open Manage installed you can use the omreport command to provide information on the Raid status.
          My setup is very basic, as I don't know enough to parse the information from omreport in a more complex way.
          Zabbix.agend.conf
          UserParameter=raid.disks,%systemroot%\system32\windowspowershell\v1.0\powershell.exe -nologo C:\zabbix\zbx_raid_disks.ps1
          zbx_raid_disks.ps1
          omreport storage vdisk controller=0 | ?{$_ -match "^status"} | %{$status=1}{if($_ -notlike "*OK*"){$status=0}}{$status}
          So now if your raid status is *Ok* it will return a 1. If a drive fails or any other problem it will return a 0.
          You can then make a template and trigger for raid.disks.
          I use this same method for intrusion,temp, etc.
          I am working on a better way to parse the information to actually return values rather than just OK or Problem.
          This method was taken from a much older zabbix thread.
