How to monitor if a unix socket exists?
  • ludiegu
    • Oct 2020
    Hello all, I am trying to make a custom template that checks if the unix socket:
    /run/php/php7.2-fpm.sock
    exists. I tried the
    vfs.file.exists
    , but it does not work as expected:
    zabbix_agentd -t "vfs.file.exists[/run/php/php7.2-fpm.sock]"
    vfs.file.exists[/run/php/php7.2-fpm.sock] [u|0]
    but the file exists:
    ls -l /run/php/php7.2-fpm.sock
    srw-rw---- 1 www-data www-data 0 Sep 9 08:46 /run/php/php7.2-fpm.sock
    the OS is an Ubuntu 18.04.
    seems like there is something strange with the
    /run
    , Can someone help me understanding why it is not working and/or suggest another way to accomplish what I need?
    Thanks for your time!
  • tim.mooney
    • Dec 2012
    • 1429
    Read the documentation for vfs.file.exists[], including the description of the 2nd argument.
    • ludiegu
      • Oct 2020
      Thanks for your reply. If I am not mistaken, it does not work with unix sockets, right?
      Do you have a suggestion on how to achive what I need? I am pretty new to zabbix.
      Thanks!
      • tim.mooney
        • Dec 2012
        • 1429
        What version of Zabbix are you using?
        • ludiegu
          • Oct 2020
          I am using 4.4
          • tim.mooney
            • Dec 2012
            • 1429
            The documentation I was referencing shows that the socket type is supported at Zabbix 5.0.2 and later.
