Zabbix doesn't work
  • vsmjoao
    • Oct 2020
    • 21
    Zabbix doesn't work
    Hi guy, I'm John.
    I'm trying to configure the Zabbix server but I'm not getting it. The web interface shows that the server isn't working on port 10051.
    When I enter the command "systemctl status zabbix-server" it returns this error message:
    [root@zabbix ~]# systemctl status zabbix-server.service
    ● zabbix-server.service - Zabbix Server
    Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor pres>
    Active: active (running) since Mon 2020-10-05 09:54:18 -03; 22s ago
    Process: 17747 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=1/FAILURE)
    Process: 17758 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0>
    Main PID: 17760 (zabbix_server)
    Tasks: 47 (limit: 23815)
    Memory: 50.5M
    CGroup: /system.slice/zabbix-server.service
    ├─17760 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
    ├─17761 /usr/sbin/zabbix_server: configuration syncer [synced configuration>
    ├─17762 /usr/sbin/zabbix_server: housekeeper [startup idle for 30 minutes]
    ├─17763 /usr/sbin/zabbix_server: timer #1 [updated 0 hosts, suppressed 0 ev>
    ├─17764 /usr/sbin/zabbix_server: http poller #1 [got 0 values in 0.001025 s>
    ├─17765 /usr/sbin/zabbix_server: discoverer #1 [processed 0 rules in 0.0029>
    ├─17766 /usr/sbin/zabbix_server: history syncer #1 [processed 0 values, 0 t>
    ├─17767 /usr/sbin/zabbix_server: history syncer #2 [processed 0 values, 0 t>
    ├─17768 /usr/sbin/zabbix_server: history syncer #3 [processed 0 values, 0 t>
    ├─17769 /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 t>
    ├─17770 /usr/sbin/zabbix_server: escalator #1 [processed 0 escalations in 0>
    ├─17771 /usr/sbin/zabbix_server: proxy poller #1 [exchanged data with 0 pro>
    ├─17772 /usr/sbin/zabbix_server: self-monitoring [processed data in 0.00008>
    ├─17773 /usr/sbin/zabbix_server: task manager [processed 0 task(s) in 0.000>
    ├─17774 /usr/sbin/zabbix_server: poller #1 [got 0 values in 0.000199 sec, g>
    ├─17775 /usr/sbin/zabbix_server: poller #2 [got 0 values in 0.000592 sec, g>
    ├─17776 /usr/sbin/zabbix_server: poller #3 [got 0 values in 0.000042 sec, g>
    ├─17777 /usr/sbin/zabbix_server: poller #4 [got 0 values in 0.000068 sec, g>
    ├─17778 /usr/sbin/zabbix_server: poller #5 [got 0 values in 0.000045 sec, g>
    ├─17779 /usr/sbin/zabbix_server: unreachable poller #1 [got 0 values in 0.0>
    ├─17780 /usr/sbin/zabbix_server: trapper #1 [processed data in 0.000000 sec>
    ├─17781 /usr/sbin/zabbix_server: trapper #2 [processed data in 0.000000 sec>
    ├─17782 /usr/sbin/zabbix_server: trapper #3 [processed data in 0.000000 sec>
    ├─17783 /usr/sbin/zabbix_server: trapper #4 [processed data in 0.000000 sec>
    ├─17784 /usr/sbin/zabbix_server: trapper #5 [processed data in 0.000000 sec>
    ├─17785 /usr/sbin/zabbix_server: icmp pinger #1 [got 0 values in 0.000196 s>
    ├─17787 /usr/sbin/zabbix_server: icmp pinger #2 [got 0 values in 0.000061 s>
    ├─17788 /usr/sbin/zabbix_server: icmp pinger #3 [got 0 values in 0.000191 s>
    ├─17789 /usr/sbin/zabbix_server: icmp pinger #4 [got 0 values in 0.000052 s>
    ├─17790 /usr/sbin/zabbix_server: icmp pinger #5 [got 0 values in 0.000073 s>
    ├─17791 /usr/sbin/zabbix_server: icmp pinger #6 [got 0 values in 0.000033 s>
    ├─17792 /usr/sbin/zabbix_server: icmp pinger #7 [got 0 values in 0.000034 s>
    ├─17794 /usr/sbin/zabbix_server: icmp pinger #8 [got 0 values in 0.000177 s>
    ├─17795 /usr/sbin/zabbix_server: icmp pinger #9 [got 0 values in 0.000039 s>
    ├─17796 /usr/sbin/zabbix_server: icmp pinger #10 [got 0 values in 0.000067 >
    ├─17798 /usr/sbin/zabbix_server: alert manager #1 [sent 0, failed 0 alerts,>
    ├─17799 /usr/sbin/zabbix_server: alerter [connecting to the database]
    ├─17801 /usr/sbin/zabbix_server: alerter [connecting to the database]
    ├─17802 /usr/sbin/zabbix_server: alerter [connecting to the database]
    ├─17803 /usr/sbin/zabbix_server: preprocessing manager #1 [queued 0, proces>
    ├─17804 /usr/sbin/zabbix_server: preprocessing worker #1 starting
    ├─17805 /usr/sbin/zabbix_server: preprocessing worker #2 starting
    ├─17807 /usr/sbin/zabbix_server: preprocessing worker #3 starting
    ├─17809 /usr/sbin/zabbix_server: lld manager #1 [processed 0 LLD rules duri>
    ├─17810 /usr/sbin/zabbix_server: lld worker [connecting to the database]
    ├─17811 /usr/sbin/zabbix_server: lld worker [connecting to the database]
    └─17812 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
    Oct 05 09:54:18 zabbix.intranet systemd[1]: Starting Zabbix Server...
    Oct 05 09:54:18 zabbix.intranet systemd[1]: zabbix-server.service: Supervising process>
    Oct 05 09:54:18 zabbix.intranet systemd[1]: Started Zabbix Server.
    How to solve this problem?
    I'm using Centos 8 and Zabbix 5.
  • zaicnupagadi
    • Dec 2010
    • 73
    Set Debug to 5, and send here the outoput after starting the server, also look for any clues in jouralctl log
    BTW. how have you installed zabbix? Have you gone throught any tutorial? if yes send a link.
    • Atsushi
      • Aug 2013
      • 2028
      Please check your SELinux settings.
      Is communication from the web server to the zabbix_server process blocked?
      ex. If SELinux is enabled
      # setsebool -P httpd_can_connect_zabbix on
      You may also need to add another setting.
      • ZaBeast
        • Sep 2019
        • 42
        Like Atsushi said it may be down because of Selinux, use this tutorial to configure SELinux for Zabbix.
        • vsmjoao
          • Oct 2020
          • 21
          Thank you. It solved my problem.
