Problems with the template Rabbitmq Nodes
  • rubenjara
    • Oct 2020
    Hello everyone, I am telling you about the problem, I am trying to monitor the rabbitmq cluster that I have in my linux machine, and I find the problem that the Nodes template does not work, it does not show any data. Instead, the Rabbit cluster template works perfectly.
    Zabbix agent is working perfectly, also, for extra info, in the part of the macros of the node template, i set the rabbit password and user, as the same user and pass that i use for acces to my rabbitmq web service. the port is being configured. The cluster is made ny 3 servers, should i add the template node in all the hosts that make up the cluster? fot the moment i only set up the templates in the first one (the master)
    Any idea why that might be?
    Thank you!
