Problem with log monitoring
  • kokox232
    • Sep 2020
    • 13
    Hello Guys,
    I have a problem with correct monitoring of log file. Prior I've created a zabbix alert about incoming new files into log folder. It works. I use vfs.file.time[/path/pathLOG_2020-09-25.txt,modify] with trigger "fuzzytime". But It doesn't resolve my problem, cause I have to monitor content, especially certain word "Error"
    I don't know how to do this. I was trying l
    logrt.count["/path/path/LOG_*.txt","Error"]
    What do you think? What is the problem?
  • GPegel
    • Dec 2015
    • 113
    I'm using this to see if the message "syserror" does appear in the log files:
    log[/log/app/node_name/error_log.log,"syserror","UTF-8",100]
    And that one works like a charm.
    • kokox232
      • Sep 2020
      • 13
      GPegel, thanks for answer!. Could you explain me what "UTF-8" and then "100" means? In my case is another problem, because every day log file is changed. Do you know how to fix it?
      • Hamardaban
        • May 2019
        • 2713
        Sacral knowledge only for you :-)
        https://www.zabbix.com/documentation...rted_item_keys
        Look for
        log[file,<regexp>,<encoding>,<maxlines>,<mode>,<output >,<maxdelay>,<options>]
        log.count[file,<regexp>,<encoding>,<maxproclines>,<mode>,<ma xdelay>,<options>]
