WEB Interface Zabbix with browser
  • jirayatv
    • Sep 2020
    In English :
    I need help with two things about the Zabbix interface:
    First thing:
    When you want to access the Zabbix interface via the web browser, you enter http://hostname_server/zabbix. I would like to know if it is possible to access the Zabbix web interface without putting the /zabbix , that is, just by putting http://hostname_server ? When you don't put the /zabbix it displays apache, but I would like to display Zabbix directly.
    Second thing:
    I created two MAPs on Zabbix, these MAPs are displayed on the dashboard. And as a company, we would like to display the three MAPs on a big TV. Except that we don't want to display these MAPs at the same time. We would like to display them one by one, without anything around them (without the Zabbix menu, without the system information, without the problems, etc). And I wanted to know if it was possible to configure a URL for these MAPs, i.e., just by typing the URL, I come across the MAP only and nothing else in order to display it in large on the TV.
    I did my research but nothing relevant unfortunately....
    I hope someone will be able to help me.
    Thank you in advance.
    Regards,
    In French :
    Bonjour,
    J'aurais besoin d'aide pour deux choses sur l'interface Zabbix :
    Première chose :
    Quand on veut accéder à l'interface de Zabbix via le navigateur web, on entre http://hostname_server/zabbix. J'aimerais savoir s'il est possible d'accéder à l'interface web de Zabbix sans mettre le /zabbix , c'est-à-dire, juste en mettant http://hostname_server ? Quand on ne met pas le /zabbix ça affiche apache, mais moi je voudrais afficher Zabbix directement.
    Deuxième chose :
    J'ai créé deux MAP sur Zabbix, ces MAP sont d'ailleurs affichées sur le tableau de bord. Et en entreprise, nous souhaitons afficher sur une grande TV, les trois MAP. Sauf que nous voulons pas afficher ces MAP en même temps. On voudrait les afficher une par une, sans rien autour (sans le menu Zabbix, sans les informations système, sans les problèmes, etc). Et je voulais savoir s'il était possible de configurer un URL pour ces MAP, c'est-à-dire, juste en tapant l'URL, je tombe sur la MAP uniquement et rien d'autres afin de l'afficher en grand sur la TV.
    J'ai fait mes recherches mais rien de pertinent malheureusement....
    J'espère que l'on pourra m'aider.
    Je vous remercie d'avance.
    Cordialement,
  • Hamardaban
    • May 2019
    • 2714
    First answer: Zabbix's frontend is a regular php site. Settings are determined by the configuration of the web server used. As you configure it, it will work.
    The second answer: is that you can use screens and slide shows https://www.zabbix.com/documentation...sation/screens. https://www.zabbix.com/documentation...isation/slides.
    P.S.
    Lisez la documentation - tout est écrit là!
    • jirayatv
      jirayatv commented
      Thank you very much
  • mircsicz
    • Oct 2020
    • 10
    Originally posted by jirayatv
    In English :
    First thing:
    Check this
    • jirayatv
      jirayatv commented
      Hello, I'll test it
    • jirayatv
      jirayatv commented
      I did it. Thank you very much
  • mircsicz
    • Oct 2020
    • 10
    What you do is integrate the map into a screen and then you add your three screen into a slideshow and you're done...
    • jirayatv
      jirayatv commented
      Thank you very much
