Dear all,
How do you add a 48 port switch and monitor all interfaces?
In dashboard there is not enough room to place all interfaces as widgets (there is if you make them really small)
In "Screens" you can do it, but for every interface you have to specify height and width. This is a thing which i don't understand.
If I setup a screen with 2 columns and 25 rows, isn't it obvious what i want? Why do I have to specify the size of each graph?
This creates another problem, if i do the screen on a 24 inch monitor it looks ok, but only on the 24 inches monitors,
if you access the same screen on a 15 inch laptop, the sizes are the same and don't fit, you have to browse all around the web page (using the bottom scroll for left - right)
So, what are you using in zabbix to monitor interfaces of a switch? Is there a way to make these graphs auto resizing when resolution changes or browser size is changed?
Thank you and it's appreciated.
