Some items failed while using input-file from zabbix_sender
  • Ferke85
    • Apr 2020
    I use generated input-file for zabbix_sender, but I have a problem with it.
    It shows some failed items, but I cannot recognize which ones aren't processed by the server.
    I tried the verbose option (-vv), but the result almost the same. At least there is no useful information about the failed items.
    Is there any way to know the problematic items?
    Br,
    Ferke
  • LenR
    • Sep 2009
    • 1011
    Try them one at a time, check that you aren't sending float to numeric, look at each item's last timestamp.
    • Ferke85
      • Apr 2020
      I tried one by one and found the failed ones. All of those items are missing from the Zabbix server. I think it would be useful to give detailed information when something fails, at least with the verbose option.
