How to retrieve the itemid of a web scenario to use it with history.get
  • zoveress
    • May 2019
    Is there a way to retrieve the itemid of a certain web scenario to be able to pull history using get.history API call?
    The issue is to get history for example of a response code you need to have an itemid.
    If you pull data using
    httptest.get it doesn't provide the itemid. I can access the history from the GUI but I need to be able to get that data using the API.
    Any suggestions?
  • Aravindhan
    • Aug 2022
    Get the Item IDs of Web Scenarios by using following request by adding Web Items
    "jsonrpc": "2.0",
    "method": "item.get",
    "params": {
    "output": "extend",
    "hostids": "10585",
    "webitems": true,
    "sortfield": "name"
    "auth": "93216dc4bffd00d6d2af1ddaa909d0bf8b0e8ac22b50e eb62 6bfd05d3c9c3b3d",
    "id": 1
    • likvi
      • Apr 2022
      I have the same problem. I'm even not enable to get data from computed item! Only data I can get are from "Failed step of scenario xxx".
      Here is a code I'am using. Please can anyone help?
      $params = array(
      'itemids' => array('61730'),
      'sortfield' => array('clock'),
      'sortorder' => array('DESC'),
      'limit' => 10
      $result = $zbx->call('history.get',$params);​
