Can you help me out with a simple regular expression / macro?
  • bog
    • Oct 2020
    Good evening,
    I'm monitoring some switches with Zabbix. Discovery found out (with cisco net template snmpv2) 9k items from which I only use 4k. The rest I have manually disabled them.
    Even disabled, they do not disappear, from graphs, triggers, items, because they are still discovered. Obviously
    I spent a lot of time trying to filter them out by name but I cannot get it done. The interfaces which I do not want are "Interface VLAN", "stackport" and "stacksub" (once again, filter by name was my intention)
    In regular expressions, return in false ^(Interface VLAN|StackSub|StackPort)*$
    This is what I tried but not working. I tried the same expression in macros in Cisco template.
    Thank you for your time.
  • LenR
    • Sep 2009
    • 1011
    What is the "*" for? Are those the full string or do they have something followking, like "Interface VLAN 1"? If so, then you may want ^(Interface VLAN|StackSub|StackPort).*$. But that made me wonder about the $ at the end.
    I test on regex101.com :-)
    • bog
      • Oct 2020
      I made some progress. It looks like i got rid of stacksub and stackport, but not interface vlan. it should had work tho, isn't the same principle?
      the name of the interfaces is Interface Vlan-1() ; Interface Vlan-2() and all the way to Interface Vlan-2000(). I tried various combinations (vlan, vlan-, interface vlan...) but it doesn't want to go away.
      • Hamardaban
        • May 2019
        • 2714
        Regex expressions are case-sensitive.
        ^(Interface Vlan|StackSub|StackPort).*$
        • bog
          • Oct 2020
          Thank you but still no result. The vlan interfaces get discovered
          • Hamardaban
            • May 2019
            • 2714
            Check you strings at regex101.com
            • bog
              • Oct 2020
              it finally worked
              template, filters, (^VLAN).*$
              4500 items are no longer discovered and will be deleted
              You both are good, thanks a lot.
              • LenR
                • Sep 2009
                • 1011
                The filter sees what is returned in discovery, in your case "VLAN", I think you shared the item descriptions "Interface VLAN" which is from the prototype format
