CPU entitlement monitor on AIX
  • mveiga.ss
    • Mar 2015
    I would like to know if anybody was able to setup monitoring of entitled CPU for an AIX LPAR (virtual server)?
    I am trying to use system.stat[cpu,ec] and would like to have it alert if CPU entitlement has been more than 100% for more that 30 minutes.
    Running Zabbix 2.2 on CentOS 6.6 and the AIX client is running AIX 7.1
    Thanks in advance,
    Marcelo Veiga.
  • geniepage
    • Sep 2015
    • 34
    Hello ,
    I have on some aix lpars problem with collection of EC. If you need it, actually You have to write own script used in UserParameters conf. It is the simplest way how to dig data from aix, which are not supported in aix naturally.
    Regards
    Genie
