When Trigger fires it should only be "Information" not "Problem"
  • testato
    • Oct 2020
    Hello Zabbix Friends :-)
    I have a Trigger that checks if a specific user is logged on via rdp.
    It shows up as a problem in zabbix dashboard with alarm sound and so on.
    But can I configure it that way that it only shows up as Informational and not as a Problem?
    Trigger serverity already is "Information".
    I just want to have the information on hand when I need to "Oh, user x is already active via rdp").
    Thanks a lot
    Maybe you have an idea
  • testato
    • Oct 2020
    Hi.
    I think I do understand.
    However my question is if for this particular trigger it can be configured to show Information instead of Problem in Status field.
      I think you don't have the basics...
      Trigger state is OK or PROBLEM... nothing else, no "information" state.
