Administration > General > Regular expressions > test feature: not working
  • catkins
    • Feb 2020
    • 19
    Testing regex to match an integer. Administration > General > Regular expressions > New regular expression. Using test string "1" without the quotes and expression type "Character string included"
    • ^[[:digit:]]+$ did not match
    • [[:digit:]]+ did not match
    • \d+ did not match
    • \d did not match
    • .* did not match
    • 1 matched
    • ^1$ did not match
    Tested same at https://regex101.com/ using flavour PCRE(PHP) and function Match. All matched
    Versions:Debian package libpcre3 was installed. Re-installed it. Same.
    If I have not misunderstood something relevant, how to investigate and hopefully fix?
  • catkins
    • Feb 2020
    • 19
    Thanks cyber
    • raoel
      • Dec 2020
      • 9
      what was the solution?
      • catkins
        • Feb 2020
        • 19
        Sorry, I do not remember. I checked issues and logs from Oct 2020 but did not find a reminder
        • raoel
          • Dec 2020
          • 9
          :-D
          • catkins
            • Feb 2020
            • 19
            LOL
            To make it even more frustrating -- if I understand this thread correctly -- cyber did answer > I found the answer satisfactory > cyber's answer was removed > I forgot
              "Character string not included" and everything works...
              • catkins
                • Feb 2020
                • 19
                Thanks Cyber, that was what I was doing wrong
