Linux Load Average adjustments
  • plattnat
    • Sep 2020
    Hi Everyone,
    I'm new to adjusting triggers, i'm trying to work out how to adjust the Template Module Linux CPU by Zabbix agent so it doesn't warn me about loads it doesn't like for example 5,5,5 where i would want 10,10,10? Any ideas?
  • tim.mooney
    • Dec 2012
    • 1436
    Review the documentation for the templates themselves, for example: https://git.zabbix.com/projects/ZBX/...lates/os/linux
    And review the Zabbix documentation for macros, https://www.zabbix.com/documentation.../config/macros
    All of the official templates make use of user macros to allow you to easily override many of the settings in the template. You just need to review the template docs to find the right macro name, and then set a macro override.
    • plattnat
      • Sep 2020
      So in the marco section of that trigger i would put {$LOAD_AVG_PER_CPU.MAX.WARN} 15
      Would that be right?
