we have several teams that are looking server monitoring infrastructure.
So we need to create 2 different problem widget .. One is standard - see all problems ( triggers ) from the server
Other one is on team that should look only hardware ( Like CPU, DIsk , Swap and Memory )
So I tried to create template with new hostgroup, to add from other templates only necessary items / triggers and at the moment that I connect some host to the group and put only this group to be seen in problems I shows all triggers again .
Is any way to create such kind of widget with only required items/triggers ?
Regards,
Georgi
Regards,
Georgi
