Hello to all,
I have a system that should return value under 5 sec and that is the trigger from the problem I set.
But often ( especially in the middle of the night) it just go over it and in next check it returns under. And it it happens cause check is set to 5 min , support want wait 10 min to see if it return or if it serious problem and they make escalation.
Is it possible to create rule that will wait for 2 or 3 checks before rise the event in dashboard problems ?
Regards,
Georgi
P.S.: Im using the latest Zabbix - 5.0.4
Regards,
Georgi
