CPU load percentage
  • littleblackdog11
    • Oct 2020
    CPU load percentage
    s it possible to get the CPU load percentage, instead of a decimal value (0.01, etc.)?
    I would like to know if I'm using 10% of the CPU or 100% of the CPU, instead of the values that I am currently receiving. This would be similar to the Windows Task Manager value, only for the linux agent.
    Is there a key for this?
  • NilsA
    • Sep 2020
    • 102
    I have been using system.cpu.util for this metric. Which one are you using to get the percentages decimal?
