Hi folks, I hope I am not annoying with my question. I have been using zabbix since 1.6 and I am currently at 1.8.5. I installed zabbix 2.4 and moved the database to the new server and upgraded it.
Everything seems to work fine but the upgrade pulled the old templates (e.g. template_windows, etc...) so the new ones (e.g. template_os_windows) are not there.
The process I went to update the database where to used the patch.sql from v2.0 then the zabbix_server process took the rest after first run.
Do you have any suggestion to move have the new templates while not losing the old information of the old values/historic data?
Thanks in advance.
Thanks in advance.
