Monitoring Certificates SSL using SNMP Agent
  • Rash92
    • Jul 2020
    • 25
    Hello Zabbix community ,
    I'm using Zabbix SNMP agent to monitor equipements and hosts , and I need to monitor SSL Certificates , I followed steps in the URL below but items can not do the job :
    https://medium.com/zabbix-tutorials/...x-860279519238
    here below my configuration in /etc/zabbix/zabbix-agentd.conf .
    ### Option: DenyKey
    # Deny execution of items keys matching pattern.
    # Multiple keys matching rules may be defined in combination with AllowKey.
    # Key pattern is wildcard expression, which support "*" character to match any number of any characters in certain position. It might be used in both key name and key arguments.
    # Parameters are processed one by one according their appearance order.
    # If no AllowKey or DenyKey rules defined, all keys are allowed.
    # Unless another system.run[*] rule is specified DenyKey=system.run[*] is added by default.
    # Mandatory: no
    # Default:
    #DenyKey=system.run[*]
    ### Option: EnableRemoteCommands - Deprecated, use AllowKey=system.run[*] or DenyKey=system.run[*] instead
    # Internal alias for AllowKey/DenyKey parameters depending on value:
    # 0 - DenyKey=system.run[*]
    # 1 - AllowKey=system.run[*]
    # Mandatory: no
    ### Option: LogRemoteCommands
    # Enable logging of executed shell commands as warnings.
    # 0 - disabled
    # 1 - enabled
    # Mandatory: no
    # Default:
    LogRemoteCommands=0
    Kindly find attached captures of items configuration and also the error message .
    Could someone help me please to fix this issue ASAP ?
    Item type... Not "Simple check" but "Zabbix Agent"
    and no you cannot run that script over snmp interface...
      I suppose you should really go and read that tutorial again and read it carefully. Pay attention what and where is configured...
