How do you tweak mounted filesystem discovery?
  • meatwad
    • Aug 2020
    There's a filesystem that exists on some of my linux boxes, /syslog, that's not getting picked up by the mounted filesystem discovery. How can I add that so it gets added to the hosts on which it exists? I think it's getting excluded from the $VFS.FS.FSNAME.NOT_MATCHES macro but I'm not sure what the best way to tweak it.
    Thanks!
  • meatwad
    • Aug 2020
    Resolved. In case anyone else runs into the same thing, I updated the "Template Module Linux filesystems by Zabbix agent" > Macros > ${VFS.FS.FSNAME.NOT_MATCHES} > Value. I added a '$' after /sys so it would explicitly match the /sys filesystem and not anything else.
