Hi, i need some help how to display uptime of mikrotik device on screen in format "uptime". If I create item for uptime monitoring so I set units as "uptime" but if i add uptime check as a plain text to screen, i always get some timestamp or so (on "Latest data" or on map item's label i have correct value).
Please, it is possible to add correct value on screen?
Many thanks
Many thanks
