Firewall port opening!
  • AlishaSandy
    • Oct 2020
    Hi All,
    ufabet
    Do we need to open the ports 10051 and 10050 in bidirectional mode at firewall level ?
    Alisha
  • poxeron
    • Sep 2020
    • 52
    hmm. dependence of checks passive\active ?
    • Hamardaban
      • May 2019
      • 2714
      SERVER:(>1024) ——> PASSIVE_AGENT:10050
      SERVER:(>1024) <—— established tcp connect —— PASSIVE_AGENT:10050
      SERVER:10051 <————- ACTIVE_AGENT:(>1024)
      SERVER:10051 —— established tcp connect ——> ACTIVE_AGENT:(>1024)
      • Iggy
        • May 2023
        It is not so clear.
        Do Server - Agent communication needs to be bidirectional in passive mode or in active mode?
        In most cases, vendor make it clear if communication needs to be bidirectional. In this case, it is not clearm and that info is important in our environment.
          • 4949
          Yes it needs to be bidirectional, as Hamardaban already pointed... Your FW should allow "answers" back to initiating side... with passive agent, initiator is server/proxy, with active agent, initiator is agent.
