Is there a way I can create a widget in a dashboard, and inside the widget I can link to other dashboards? A example is, we have a dashboard for dev. In dev there are many different sites we monitor. The main Dev dashboard displays the overall monitoring of all the dev sites, but we would like to be able to navigate to another dashboards directly from that main Dev dashboard. Is there a way I can create a widget with links to the other dashboards in it?
I had wrote it after gave up to find a solution.
