Tables missing in database.
  • elementalmist
    • Oct 2020
    Hi All,
    I was basically just thrown into a Zabbix Admin role at my company with no prior experience with Zabbix or Galera/MySQL and its been broken since the day the last guy left
    I've been doing my best to repair it, and i've gotten it working mostly. But i'm running into an error.
    • Error in query [SELECT MIN(ht.c) AS min_clock FROM (SELECT MIN(ht.clock) AS c FROM trends_uint ht WHERE ht.itemid='50292' UNION ALL SELECT MIN(ht.clock) AS c FROM trends_uint ht WHERE ht.itemid='50287') ht] [Table 'zabbix.trends_uint' doesn't exist]
    This table seems to exist on the proxys, but not the servers. I'm not sure how it would've been deleted. Is there any way to restore this table? I looked in /var/lib/mysql/zabbix and I don't see the trends_uint.ibd there. Just the FRM and a bunch of other files.
    (Sorry in advance if this is a dumb question)
  • tim.mooney
    • Dec 2012
    • 1436
    Sorry you've inherited a mess. That's a tough situation to be in.
    It seems like your trends_uint table may have been partitioned, using mysql Partitioning. If you connect up to mysql using the mysql command-line monitor and then do:
    use zabbix;
    SHOW CREATE TABLE trends_unit\G
    It should tell you whether that table is a partitioned table.
    What version of Zabbix are you running? How big is your monitoring environment? You can get the # of items, triggers, hosts, via the web front end. It would also be useful to include the calculated value for NVPS (new values per second, a measure of how busy your server can expect to be).
    • elementalmist
      • Oct 2020
      use zabbix;
      Hey Tim,
      Thanks for the help! Appreciate the sympathy haha.
      i'm getting this back.
      We're running Zabbix 3.0.27. Which is apparently the only version vetted by my leadership
      We have two servers (primary, backup), and 2 proxy pairs (primary1, backup1, primary2, backup2).
      The tables that are missing seem to exist on the proxies but not the servers.
      We have 3744 hosts that we're monitoring 763 Linux boxes, and 1981 Windows Server nodes.
