Adding value of Zabbix Agent Availibility on Map label
  • williamk
    • Jun 2020
    Hi all,
    I am trying to display the value of Zabbix Agent Availibility Item on a map lablel. The key for this item is:
    zabbix[host,agent,available]
    So on the label for the host I am entering:
    {HOSTNAME}
    ZabbixAgent: {{HOSTNAME}:zabbix[host,agent,available].last(0)}
    But I get an *UNKNOWN* for that value when I display the map. Usually means my format is wrong. What would be the correct way to display this value? Would like it to show as "Available" or "UnAvailable". I am running Zabbix 5.0.2.
