Disk trigger cannot evaluate
  • Toms
    • Mar 2020
    I have a problem on two servers about the triggers on disk space usage. I use the default Linux template "Template Module Linux filesystems by Zabbix agent" for all my servers (about 150).
    On those two servers, I see the following message on the trigger page (for "/", "/boot" and "/data" partition):
Name:	Configuration of triggers.png
    Did anyone ever encounter the same issue ?​​​
  • AVP.Riga
    • Oct 2020
    • 59
    Good day,
    In this case, everything works exactly as it should work - a string value is returned and Zabbix cannot calculate it.
    Please try to use Preprocessing to clean up TB letters and and multiply them.
    • Toms
      • Mar 2020
      I found my problem!
      In the {$ DISK.SPACE.LEFT.CRIT} macro used in the trigger, I used "0.1TB" instead of "0.1T".
      Thanks for your reply, she guided me to the solution.
      • AVP.Riga
        • Oct 2020
        • 59
        Good morning,
        You're welcome!
