HOWTO: Zabbix 2.4 - Postgres SQL to reset Trigger's state
  • pablos
    • Mar 2015
    • 22
    I wanted to monitor my syslog's for login success and failures. I wanted one alert per attempt. I also wanted the data to clear. Using .nodata() resulted in duplicate email messages[1] - seems to be "by design."
    I removed .nodata() from my Trigger definition but the issues remained on the Monitoring > Dashboard. I found some partially working SQL[2] (for MySQL) which I transformed to work with Zabbix 2.4 and PostgreSQL:
    -- Flip a "trigger"'s "value" to 0 so it no longer appears
    -- on the Monitoring > Dashboard as an issue.
    -- The SQL below uses two filters:
    -- o  applications.name = 'syslog'
    -- o  Any item that is older than 60 (+ 60) seconds
    UPDATE triggers
    SET    value = 0
    FROM   hosts
    INNER  JOIN applications
       ON  hosts.hostid = applications.hostid
    INNER  JOIN items
       ON  hosts.hostid = items.hostid
    INNER  JOIN items_applications
       ON  items.itemid               = items_applications.itemid
       AND applications.applicationid = items_applications.applicationid
    INNER  JOIN functions
       ON  items.itemid               = functions.itemid
    INNER JOIN triggers t2
       ON  functions.triggerid = t2.triggerid
    WHERE  items.templateid   IS NOT NULL
    AND    applications.name   = 'syslog'
    AND    triggers.value      = 1
    AND    triggers.triggerid  = t2.triggerid
    AND    items.mtime        <= extract(epoch from now()) + 60;
    References
    [1] - https://support.zabbix.com/browse/ZBX-8114
    [2] - https://www.zabbix.com/forum/showthread.php?t=38398
