Notification when action fails
  • porlock
    • May 2012
    • 13
    Consider this scenario I have a action that use an e-mail notification, assume that my SMTP server is down for some reason, if that will happen i want to conditionally (if my standard email action fails) launch an other action that will send message by other media (sms for example) or run a custom script. It is possible to do so ?
  • zabbix_gunner
    • Feb 2015
    • 38
    monitor smtp
    why not monitor the smtp server separately ?
    • waleedmortaja
      • Dec 2022
      Any updates on this?
      Zabbix 6.2 is out, but I could not find a way to do it yet.
      Originally posted by zabbix_gunner
      monitor smtp
      It would not be enough.
      Consider a scenario of having an important server (a web server for example), and SMTP server, and that you have configured actions such that in case of web server fail, send email (using SMTP server), and in case of SMTP server fail, send SMS.
      Now when SMTP server fails, you would receive the SMS, but if the web server failed just after it, the email notification action would fail and you would be unaware of that failure.
      That's when a fall-back action would come the rescue ,, we hope.
