Monitoring Traffic from PPPOE Interface Mikrotik Using SNMP
  • LEPAK
    • Nov 2020
    Hi all,
    so i am new to zabbix so i need help to do thing in zabbix. so i have mikrotik connected to zabbix via SNMP. now i want to monitoring ALL of PPPOE interfaces on that mikrotik. zabbix can read all the interfaces at first but because this is PPPOE Interfaces sometimes the interface gone (Disconnected) then when that PPPOE Connected again zabbix give an error about cannot create graph because it already existed.
    right now the solution that come to my mine is to make 0 value to keep recource file when disconnected, but this solution make the history about previous graph also removed. I just want zabbix use previous PPPOE graph when discover PPPOE interface with the same name. anyone have an idea? thanks
  • joemyburgh
    • Apr 2020
    I have the same problem, is there a way to keep the interface with zero values until it reconnects?
    • LEPAK
      • Nov 2020
      no one can't give suggestion or solution ?
