Hello everyone,
I've upgraded our monitoring system from 1.1beta2 to 1.1.1 and am trying to get my head around the new look actions. I have triggers and actions enabled for a particular item which is working fine when the state changes.
However when I alter the trigger to deliberately call a action I get the alert saying "processor load high on hostname : ON" but when I change the trigger back I get the alert that still says "processor load high on hostname: ON" rather than saying OFF.
It was really useful to check the alerts were working in the past by manually altering the trigger threshold which no longer seems possible.
What am I doing wrong ?
Also when adding a trigger I used to be able to look at one trigger and then alter some settings and add it or update the trigger, now I can only "save" it which isn't as convienent.
And is there a way to enable the logging of the SQL to a file so I can understand the DB structure better.
