LLD - Template Filters
  • Jeeper23
    • Mar 2015
    Hi All,
    I recently made a change to the filters on my LLD discrovery which should remove an snmp item. The item is no longer appearing on new hosts however all the old hosts still have the item as it can read it from snmp. I tried setting the Lost Item settings to 0 days however since it can read the snmp value still zabbix does not remove the Item.
    Is there a way to remove the item and its data on multiple hosts. If I go into the host and delete it then its fine however I can't really delete 10 items per host, having 200 hosts in zabbix.
    Please help!
