Help with Trigger on simple UserParameter
  • o-w
    • Apr 2015
    Hey All,
    I'm having trouble understanding triggers in Zabbix.
    I have a UserParameter, CheckSamba, that runs on a linux system with zabbix-agent running. Values are being returned (0, 1, or 2). I see these values correctly in "latest data".
    If I have a UserParameter setup. An Item setup (I selected "character" to handle the 0, 1 or 2).
    Can you help me write a trigger that sets a high alert if CheckSamba comes back with a 1 or 2? Something like...
    {hostname:CheckSamba()=(1|2)}
    Thanks for any help.
  • BDiE8VNy
    • Apr 2010
    • 680
    How about:
    {example.com:CheckSamba.last()}>0
    Where 'example.com' is your host, 'CheckSamba' is your item key and 'last()' is a trigger function that represents the last value of the corresponding item.
    Btw, in your case "Numeric (unsigend)" is probably a better choice for "Type of information"
    See:
    Configuration of Triggers
    Supported trigger functions
    • o-w
      • Apr 2015
      Thanks for the help.
      One strange thing is that when I change the UserParameter item to be Numeric (unsigned), the "make trigger" button in the list of Items for a host disappears. I can go straight into the "Triggers" menu, and i notice it has a different interface. I don't understand why that button on the list of Items page only exists for text fields? (I see now it somehow helps create a different kind of trigger then the trigger page would... but idont get it).
      I tried adding your suggestion as a "Trigger". However when I enter the regular expression you supply it returns
      "Incorrect trigger expression. Check expression part starting from "{HOST:CheckSamba.last() } >0".
      I did finally figure out the expression generator, and it came up with the exact same thing you suggested with no spaces and it took it!
      {HOST:CheckSamba.last()}>0
      Thanks for the help and discussion!
