trigger storage in mySQL
  • varick_teller
    • Jan 2014
    I accidentally dumped the triggers table in the zabbix db, . I restored just that table to an earlier backup but Zabbix frontend still shows no Triggers configured on any of the hosts or templates. The Status of Zabbix section on the dashboard is showing a number of triggers value of 1668 though.
    Are there any other tables I need to restore to get the triggers to reappear on the templates and hosts?
    Zabbix Version is 2.4.0 running on SUSE EL 11 SP3, mysql 5.5.33.
    STATUS OF ZABBIX
    Parameter Value Details
    Zabbix server is running Yes localhost:10051
    Number of hosts (enabled/disabled/templates) 233 136 / 1 / 96
    Number of items (enabled/disabled/not supported) 4346 3443 / 229 / 674
    Number of triggers (enabled/disabled [problem/ok]) 1668 1528 / 140 [221 / 1307]
    Number of users (online) 19 3
    Required server performance, new values per second 73.93 -
    Triggers
    Group Host
    Displaying 0 of 0 found
    Show filter
    Severity Status Info Last change Age Acknowledged Host Name Description
    No triggers found.
