Zabbix 5.0 strange behavior
  • 2G_Storm
    • Nov 2020
    Hi everyone,
    I have recently stumbled upon a strange behavior. There are 2 pictures attached.
    here is my proxy configuration:
    HTML Code:
    # This is a configuration file for Zabbix proxy daemon
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: ProxyMode
    # Proxy operating mode.
    # 0 - proxy in the active mode
    # 1 - proxy in the passive mode
    # Mandatory: no
    # Default:
    ProxyMode=0
    ### Option: Server
    # If ProxyMode is set to active mode:
    # IP address or DNS name of Zabbix server to get configuration data from and send data to.
    # If ProxyMode is set to passive mode:
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix server.
    # Incoming connections will be accepted only from the addresses listed here.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
    # and '::/0' will allow any IPv4 or IPv6 address.
    # '0.0.0.0/0' can be used to allow any IPv4 address.
    # Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Mandatory: yes
    # Default:
    # Server=
    Server=zabbix.my.server
    ### Option: ServerPort
    # Port of Zabbix trapper on Zabbix server.
    # For a proxy in the passive mode this parameter will be ignored.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ServerPort=10051
    ### Option: Hostname
    # Unique, case sensitive Proxy name. Make sure the Proxy name is known to the server!
    # Value is acquired from HostnameItem if undefined.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=CDS_Zabbix_Proxy
    ### Option: HostnameItem
    # Item used for generating Hostname if it is undefined.
    # Ignored if Hostname is defined.
    # Mandatory: no
    # Default:
    # HostnameItem=system.hostname
    ### Option: ListenPort
    # Listen port for trapper.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10051
    ### Option: SourceIP
    # Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: LogType
    # Specifies where log messages are written to:
    # system - syslog
    # file - file specified with LogFile parameter
    # console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    # Log file name for LogType 'file' parameter.
    # Mandatory: yes, if LogType is set to file, otherwise no
    # Default:
    # LogFile=
    LogFile=/var/log/zabbix/zabbix_proxy.log
    ### Option: LogFileSize
    # Maximum size of log file in MB.
    # 0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    LogFileSize=0
    ### Option: DebugLevel
    # Specifies debug level:
    # 0 - basic information about starting and stopping of Zabbix processes
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - for debugging (produces lots of information)
    # 5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    ### Option: EnableRemoteCommands
    # Whether remote commands from Zabbix server are allowed.
    # 0 - not allowed
    # 1 - allowed
    # Mandatory: no
    # Default:
    # EnableRemoteCommands=0
    ### Option: LogRemoteCommands
    # Enable logging of executed shell commands as warnings.
    # 0 - disabled
    # 1 - enabled
    # Mandatory: no
    # Default:
    # LogRemoteCommands=0
    ### Option: PidFile
    # Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_proxy.pid
    PidFile=/var/run/zabbix/zabbix_proxy.pid
    ### Option: SocketDir
    # IPC socket directory.
    # Directory to store IPC sockets used by internal Zabbix services.
    # Mandatory: no
    # Default:
    # SocketDir=/tmp
    SocketDir=/var/run/zabbix
    ### Option: DBHost
    # Database host name.
    # If set to localhost, socket is used for MySQL.
    # If set to empty string, socket is used for PostgreSQL.
    # Mandatory: no
    # Default:
    # DBHost=localhost
    ### Option: DBName
    # Database name.
    # For SQLite3 path to database file must be provided. DBUser and DBPassword are ignored.
    # Warning: do not attempt to use the same database Zabbix server is using.
    # Mandatory: yes
    # Default:
    # DBName=
    DBName=secret
    ### Option: DBSchema
    # Schema name. Used for PostgreSQL.
    # Mandatory: no
    # Default:
    # DBSchema=
    ### Option: DBUser
    # Database user. Ignored for SQLite.
    # Default:
    # DBUser=
    DBUser=secret
    ### Option: DBPassword
    # Database password. Ignored for SQLite.
    # Comment this line if no password is used.
    # Mandatory: no
    # Default:
    DBPassword=secret
    ### Option: DBSocket
    # Path to MySQL socket.
    # Mandatory: no
    # Default:
    # DBSocket=
    # Option: DBPort
    # Database port when not using local socket. Ignored for SQLite.
    # Mandatory: no
    # Default:
    # DBPort=
    ######### PROXY SPECIFIC PARAMETERS #############
    ### Option: ProxyLocalBuffer
    # Proxy will keep data locally for N hours, even if the data have already been synced with the server.
    # This parameter may be used if local data will be used by third party applications.
    # Mandatory: no
    # Range: 0-720
    # Default:
    # ProxyLocalBuffer=0
    ### Option: ProxyOfflineBuffer
    # Proxy will keep data for N hours in case if no connectivity with Zabbix Server.
    # Older data will be lost.
    # Mandatory: no
    # Range: 1-720
    # Default:
    ProxyOfflineBuffer=24
    ### Option: HeartbeatFrequency
    # Frequency of heartbeat messages in seconds.
    # Used for monitoring availability of Proxy on server side.
    # 0 - heartbeat messages disabled.
    # Mandatory: no
    # Range: 0-3600
    # Default:
    # HeartbeatFrequency=60
    ### Option: ConfigFrequency
    # How often proxy retrieves configuration data from Zabbix Server in seconds.
    # Mandatory: no
    # Range: 1-3600*24*7
    # Default:
    # ConfigFrequency=3600
    ### Option: DataSenderFrequency
    # Proxy will send collected data to the Server every N seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # DataSenderFrequency=1
    ############ ADVANCED PARAMETERS ################
    ### Option: StartPollers
    # Number of pre-forked instances of pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPollers=5
    ### Option: StartIPMIPollers
    # Number of pre-forked instances of IPMI pollers.
    # The IPMI manager process is automatically started when at least one IPMI poller is started.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartIPMIPollers=0
    ### Option: StartPreprocessors
    # Number of pre-forked instances of preprocessing workers.
    # The preprocessing manager process is automatically started when preprocessor worker is started.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # StartPreprocessors=3
    ### Option: StartPollersUnreachable
    # Number of pre-forked instances of pollers for unreachable hosts (including IPMI and Java).
    # At least one poller for unreachable hosts must be running if regular, IPMI or Java pollers
    # are started.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPollersUnreachable=1
    ### Option: StartTrappers
    # Number of pre-forked instances of trappers.
    # Trappers accept incoming connections from Zabbix sender and active agents.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartTrappers=5
    ### Option: StartPingers
    # Number of pre-forked instances of ICMP pingers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPingers=1
    ### Option: StartDiscoverers
    # Number of pre-forked instances of discoverers.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartDiscoverers=1
    ### Option: StartHTTPPollers
    # Number of pre-forked instances of HTTP pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartHTTPPollers=1
    ### Option: JavaGateway
    # IP address (or hostname) of Zabbix Java gateway.
    # Only required if Java pollers are started.
    # Mandatory: no
    # Default:
    # JavaGateway=
    ### Option: JavaGatewayPort
    # Port that Zabbix Java gateway listens on.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # JavaGatewayPort=10052
    ### Option: StartJavaPollers
    # Number of pre-forked instances of Java pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartJavaPollers=0
    ### Option: StartVMwareCollectors
    # Number of pre-forked vmware collector instances.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartVMwareCollectors=0
    ### Option: VMwareFrequency
    # How often Zabbix will connect to VMware service to obtain a new data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwareFrequency=60
    ### Option: VMwarePerfFrequency
    # How often Zabbix will connect to VMware service to obtain performance data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwarePerfFrequency=60
    ### Option: VMwareCacheSize
    # Size of VMware cache, in bytes.
    # Shared memory size for storing VMware data.
    # Only used if VMware collectors are started.
    # Mandatory: no
    # Range: 256K-2G
    # Default:
    # VMwareCacheSize=8M
    ### Option: VMwareTimeout
    # Specifies how many seconds vmware collector waits for response from VMware service.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # VMwareTimeout=10
    ### Option: SNMPTrapperFile
    # Temporary file used for passing data from SNMP trap daemon to the proxy.
    # Must be the same as in zabbix_trap_receiver.pl or SNMPTT configuration file.
    # Mandatory: no
    # Default:
    # SNMPTrapperFile=/tmp/zabbix_traps.tmp
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    ### Option: StartSNMPTrapper
    # If 1, SNMP trapper process is started.
    # Mandatory: no
    # Range: 0-1
    # Default:
    # StartSNMPTrapper=0
    ### Option: ListenIP
    # List of comma delimited IP addresses that the trapper should listen on.
    # Trapper will listen on all network interfaces if this parameter is missing.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: HousekeepingFrequency
    # How often Zabbix will perform housekeeping procedure (in hours).
    # Housekeeping is removing outdated information from the database.
    # To prevent Housekeeper from being overloaded, no more than 4 times HousekeepingFrequency
    # hours of outdated information are deleted in one housekeeping cycle.
    # To lower load on proxy startup housekeeping is postponed for 30 minutes after proxy start.
    # With HousekeepingFrequency=0 the housekeeper can be only executed using the runtime control option.
    # In this case the period of outdated information deleted in one housekeeping cycle is 4 times the
    # period since the last housekeeping cycle, but not less than 4 hours and not greater than 4 days.
    # Mandatory: no
    # Range: 0-24
    # Default:
    # HousekeepingFrequency=1
    ### Option: CacheSize
    # Size of configuration cache, in bytes.
    # Shared memory size, for storing hosts and items data.
    # Mandatory: no
    # Range: 128K-64G
    # Default:
    CacheSize=128M
    ### Option: StartDBSyncers
    # Number of pre-forked instances of DB Syncers.
    # Mandatory: no
    # Range: 1-100
    # Default:
    # StartDBSyncers=4
    ### Option: HistoryCacheSize
    # Size of history cache, in bytes.
    # Shared memory size for storing history data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    HistoryCacheSize=128M
    ### Option: HistoryIndexCacheSize
    # Size of history index cache, in bytes.
    # Shared memory size for indexing history cache.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    HistoryIndexCacheSize=128M
    ### Option: Timeout
    # Specifies how long we wait for agent, SNMP device or external check (in seconds).
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    Timeout=4
    ### Option: TrapperTimeout
    # Specifies how many seconds trapper may spend processing new data.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # TrapperTimeout=300
    ### Option: UnreachablePeriod
    # After how many seconds of unreachability treat a host as unavailable.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachablePeriod=45
    ### Option: UnavailableDelay
    # How often host is checked for availability during the unavailability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnavailableDelay=60
    ### Option: UnreachableDelay
    # How often host is checked for availability during the unreachability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachableDelay=15
    ### Option: ExternalScripts
    # Full path to location of external scripts.
    # Default depends on compilation options.
    # To see the default path run command "zabbix_proxy --help".
    # Mandatory: no
    # Default:
    # ExternalScripts=${datadir}/zabbix/externalscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    ### Option: FpingLocation
    # Location of fping.
    # Make sure that fping binary has root ownership and SUID flag set.
    # Mandatory: no
    # Default:
    # FpingLocation=/usr/sbin/fping
    FpingLocation=/usr/bin/fping
    ### Option: Fping6Location
    # Location of fping6.
    # Make sure that fping6 binary has root ownership and SUID flag set.
    # Make empty if your fping utility is capable to process IPv6 addresses.
    # Mandatory: no
    # Default:
    # Fping6Location=/usr/sbin/fping6
    Fping6Location=/usr/bin/fping6
    ### Option: SSHKeyLocation
    # Location of public and private keys for SSH checks and actions.
    # Mandatory: no
    # Default:
    # SSHKeyLocation=
    ### Option: LogSlowQueries
    # How long a database query may take before being logged (in milliseconds).
    # Only works if DebugLevel set to 3 or 4.
    # 0 - don't log slow queries.
    # Mandatory: no
    # Range: 1-3600000
    # Default:
    # LogSlowQueries=0
    LogSlowQueries=3000
    ### Option: TmpDir
    # Temporary directory.
    # Mandatory: no
    # Default:
    # TmpDir=/tmp
    ### Option: AllowRoot
    # Allow the proxy to run as 'root'. If disabled and the proxy is started by 'root', the proxy
    # will try to switch to the user specified by the User configuration option instead.
    # Has no effect if started under a regular user.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Default:
    # AllowRoot=0
    ### Option: User
    # Drop privileges to a specific, existing user on the system.
    # Only has effect if run as 'root' and AllowRoot is disabled.
    # Mandatory: no
    # Default:
    # User=zabbix
    ### Option: Include
    # You may include individual files or all files in a directory in the configuration file.
    # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
    # Mandatory: no
    # Default:
    # Include=
    # Include=/usr/local/etc/zabbix_proxy.general.conf
    # Include=/usr/local/etc/zabbix_proxy.conf.d/
    # Include=/usr/local/etc/zabbix_proxy.conf.d/*.conf
    ### Option: SSLCertLocation
    # Location of SSL client certificates.
    # This parameter is used only in web monitoring.
    # Mandatory: no
    # Default:
    # SSLCertLocation=${datadir}/zabbix/ssl/certs
    ### Option: SSLKeyLocation
    # Location of private keys for SSL client certificates.
    # Mandatory: no
    # Default:
    # SSLKeyLocation=${datadir}/zabbix/ssl/keys
    ### Option: SSLCALocation
    # Location of certificate authority (CA) files for SSL server certificate verification.
    # If not set, system-wide directory will be used.
    # Mandatory: no
    # Default:
    # SSLCALocation=
    ####### LOADABLE MODULES #######
    ### Option: LoadModulePath
    # Full path to location of proxy modules.
    # Mandatory: no
    # Default:
    # LoadModulePath=${libdir}/modules
    # Module to load at proxy startup. Modules are used to extend functionality of the proxy.
    # Formats:
    # LoadModule=<module.so>
    # LoadModule=<path/module.so>
    # LoadModule=</abs_path/module.so>
    # Either the module must be located in directory specified by LoadModulePath or the path must precede the module name.
    # If the preceding path is absolute (starts with '/') then LoadModulePath is ignored.
    # It is allowed to include multiple LoadModule parameters.
    # Mandatory: no
    # Default:
    # LoadModule=
    ### Option: StatsAllowedIP
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of external Zabbix instances.
    # Stats request will be accepted only from the addresses listed here. If this parameter is not set no stats requests
    # will be accepted.
    # Example: StatsAllowedIP=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Mandatory: no
    # Default:
    # StatsAllowedIP=
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSConnect
    # How the proxy should connect to Zabbix server. Used for an active proxy, ignored on a passive proxy.
    # Only one value can be specified:
    # unencrypted - connect without encryption
    # psk - connect using TLS and a pre-shared key
    # cert - connect using TLS and a certificate
    # Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
    # Default:
    TLSConnect=psk
    ### Option: TLSAccept
    # What incoming connections to accept from Zabbix server. Used for a passive proxy, ignored on an active proxy.
    # Multiple values can be specified, separated by comma:
    # unencrypted - accept connections without encryption
    # psk - accept connections secured with TLS and a pre-shared key
    # cert - accept connections secured with TLS and a certificate
    # Default:
    TLSAccept=psk
    ### Option: TLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for
    # peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    # Full pathname of a file containing revoked certificates.
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    ### Option: TLSServerCertIssuer
    # Allowed server certificate issuer.
    # Mandatory: no
    # Default:
    # TLSServerCertIssuer=
    ### Option: TLSServerCertSubject
    # Allowed server certificate subject.
    # Mandatory: no
    # Default:
    # TLSServerCertSubject=
    ### Option: TLSCertFile
    # Full pathname of a file containing the proxy certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    ### Option: TLSKeyFile
    # Full pathname of a file containing the proxy private key.
    # Mandatory: no
    # Default:
    #TLSKeyFile=/etc/zabbix/psk.key
    ### Option: TLSPSKIdentity
    # Unique, case sensitive string used to identify the pre-shared key.
    # Mandatory: no
    # Default:
    TLSPSKIdentity=CDS
    ### Option: TLSPSKFile
    # Full pathname of a file containing the pre-shared key.
    # Mandatory: no
    # Default:
    TLSPSKFile=/etc/zabbix/psk.key
    ####### For advanced users - TLS ciphersuite selection criteria #######
    ### Option: TLSCipherCert13
    # Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
    # Override the default ciphersuite selection criteria for certificate-based encryption.
    # Mandatory: no
    # Default:
    # TLSCipherCert13=
    # GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
    # Example for GnuTLS:
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # Example for OpenSSL:
    # EECDH+aRSA+AES128:RSA+aRSA+AES128
    # Mandatory: no
    # Default:
    # TLSCipherCert=
    ### Option: TLSCipherPSK13
    # Override the default ciphersuite selection criteria for PSK-based encryption.
    # Example:
    # TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA25 6
    # Mandatory: no
    # Default:
    # TLSCipherPSK13=
    # NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
    # kECDHEPSK+AES128:kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherPSK=
    ### Option: TLSCipherAll13
    # Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
    # Example:
    # TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA25 6:TLS_AES_128_GCM_SHA256
    # Mandatory: no
    # Default:
    # TLSCipherAll13=
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128 :kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherAll=
    ### Option: DBTLSConnect
    # Setting this option enforces to use TLS connection to database.
    # required - connect using TLS
    # verify_ca - connect using TLS and verify certificate
    # verify_full - connect using TLS, verify certificate and verify that database identity specified by DBHost
    # matches its certificate
    # On MySQL starting from 5.7.11 and PostgreSQL following values are supported: "required", "verify_ca" and
    # "verify_full".
    # On MariaDB starting from version 10.2.6 "required" and "verify_full" values are supported.
    # Default is not to set any option and behavior depends on database configuration
    # Mandatory: no
    # Default:
    # DBTLSConnect=
    ### Option: DBTLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for database certificate verification.
    # Supported only for MySQL and PostgreSQL
    # Mandatory: no
    # (yes, if DBTLSConnect set to one of: verify_ca, verify_full)
    # Default:
    # DBTLSCAFile=
    ### Option: DBTLSCertFile
    # Full pathname of file containing Zabbix proxy certificate for authenticating to database.
    # Mandatory: no
    # Default:
    # DBTLSCertFile=
    ### Option: DBTLSKeyFile
    # Full pathname of file containing the private key for authenticating to database.
    # Mandatory: no
    # Default:
    # DBTLSKeyFile=
    ### Option: DBTLSCipher
    # The list of encryption ciphers that Zabbix proxy permits for TLS protocols up through TLSv1.2
    # Mandatory no
    # Default:
    # DBTLSCipher=
    ### Option: DBTLSCipher13
    # The list of encryption ciphersuites that Zabbix proxy permits for TLSv1.3 protocol
    # Supported only for MySQL, starting from version 8.0.16
    # Mandatory no
    # Default:
    # DBTLSCipher13=
    and the agent of one of the monitored machines:
    HTML Code:
    # This is a configuration file for Zabbix agent daemon (Unix)
    ### Option: PidFile
    # Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_agentd.pid
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    ### Option: LogType
    # system - syslog
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    # Default:
    # LogFile=
    LogFile=/var/log/zabbix/zabbix_agentd.log
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    LogFileSize=0
    # 3 - warnings
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: AllowKey
    # Allow execution of item keys matching pattern.
    # Multiple keys matching rules may be defined in combination with DenyKey.
    # Key pattern is wildcard expression, which support "*" character to match any number of any characters in certain position. It might be used in both key name and key arguments.
    # Parameters are processed one by one according their appearance order.
    # If no AllowKey or DenyKey rules defined, all keys are allowed.
    # Mandatory: no
    ### Option: DenyKey
    # Deny execution of items keys matching pattern.
    # Multiple keys matching rules may be defined in combination with AllowKey.
    # Unless another system.run[*] rule is specified DenyKey=system.run[*] is added by default.
    # Mandatory: no
    # Default:
    # DenyKey=system.run[*]
    ### Option: EnableRemoteCommands - Deprecated, use AllowKey=system.run[*] or DenyKey=system.run[*] instead
    # Internal alias for AllowKey/DenyKey parameters depending on value:
    # 0 - DenyKey=system.run[*]
    # 1 - AllowKey=system.run[*]
    # Mandatory: no
    # 0 - disabled
    # 1 - enabled
    # Mandatory: no
    # Default:
    ##### Passive checks related
    ### Option: Server
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
    # Incoming connections will be accepted only from the hosts listed here.
    # Mandatory: yes, if StartAgents is not explicitly set to 0
    # Default:
    # Server=
    Server=zabbixproxy.cds.lan
    # Agent will listen on this port for connections from the server.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10050
    # List of comma delimited IP addresses that the agent should listen on.
    # First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: StartAgents
    # Number of pre-forked instances of zabbix_agentd that process passive checks.
    # If set to 0, disables passive checks and the agent will not listen on any TCP port.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartAgents=3
    ##### Active checks related
    ### Option: ServerActive
    # List of comma delimited IPort (or DNS nameort) pairs of Zabbix servers and Zabbix proxies for active checks.
    # If port is not specified, default port is used.
    # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
    # If port is not specified, square brackets for IPv6 addresses are optional.
    # If this parameter is not specified, active checks are disabled.
    # Example: ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
    # Mandatory: no
    # Default:
    # ServerActive=
    ServerActive=zabbixproxy.cds.lan
    # Unique, case sensitive hostname.
    # Required for active checks and must match hostname as configured on the server.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=R710CM7475J
    # Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
    # Does not support UserParameters or aliases.
    # Mandatory: no
    # Default:
    ### Option: HostMetadata
    # Optional parameter that defines host metadata.
    # Host metadata is used at host auto-registration process.
    # An agent will issue an error and not start if the value is over limit of 255 characters.
    # If not defined, value will be acquired from HostMetadataItem.
    # Mandatory: no
    # Range: 0-255 characters
    # Default:
    HostMetadata=CDS Proxmox 5
    ### Option: HostMetadataItem
    # Optional parameter that defines an item used for getting host metadata.
    # During an auto-registration request an agent will log a warning message if
    # the value returned by specified item is over limit of 255 characters.
    # This option is only used when HostMetadata is not defined.
    # Mandatory: no
    # Default:
    # HostMetadataItem=
    ### Option: HostInterface
    # Optional parameter that defines host interface.
    # Host interface is used at host auto-registration process.
    # If not defined, value will be acquired from HostInterfaceItem.
    # Mandatory: no
    # Default:
    # HostInterface=
    ### Option: HostInterfaceItem
    # Optional parameter that defines an item used for getting host interface.
    # This option is only used when HostInterface is not defined.
    # Mandatory: no
    # Default:
    # HostInterfaceItem=
    ### Option: RefreshActiveChecks
    # How often list of active checks is refreshed, in seconds.
    # Mandatory: no
    # Range: 60-3600
    # Default:
    # RefreshActiveChecks=120
    ### Option: BufferSend
    # Do not keep data longer than N seconds in buffer.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # BufferSend=5
    ### Option: BufferSize
    # Maximum number of values in a memory buffer. The agent will send
    # all collected data to Zabbix Server or Proxy if the buffer is full.
    # Mandatory: no
    # Range: 2-65535
    # Default:
    # BufferSize=100
    ### Option: MaxLinesPerSecond
    # Maximum number of new lines the agent will send per second to Zabbix Server
    # or Proxy processing 'log' and 'logrt' active checks.
    # The provided value will be overridden by the parameter 'maxlines',
    # provided in 'log' or 'logrt' item keys.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # MaxLinesPerSecond=20
    ############ ADVANCED PARAMETERS #################
    ### Option: Alias
    # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
    # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
    # Different Alias keys may reference the same item key.
    # For example, to retrieve the ID of user 'zabbix':
    # Alias=zabbix.userid:vfs.file.regexp[/etc/passwd,^zabbix:.[0-9]+),,,,\1]
    # Now shorthand key zabbix.userid may be used to retrieve data.
    # Aliases can be used in HostMetadataItem but not in HostnameItem parameters.
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Timeout
    # Spend no more than Timeout seconds on processing
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    # Allow the agent to run as 'root'. If disabled and the agent is started by 'root', the agent
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Default:
    # AllowRoot=0
    ### Option: User
    # Mandatory: no
    # Default:
    # User=zabbix
    ### Option: Include
    # Mandatory: no
    # Default:
    # Include=
    Include=/etc/zabbix/zabbix_agentd.d/*.conf
    # Include=/usr/local/etc/zabbix_agentd.userparams.conf
    # Include=/usr/local/etc/zabbix_agentd.conf.d/
    # Include=/usr/local/etc/zabbix_agentd.conf.d/*.conf
    ### Option: UnsafeUserParameters
    # Allow all characters to be passed in arguments to user-defined parameters.
    # The following characters are not allowed:
    # Additionally, newline characters are not allowed.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Range: 0-1
    # Default:
    # UnsafeUserParameters=0
    ### Option: UserParameter
    # User-defined parameter to monitor. There can be several user-defined parameters.
    # Format: UserParameter=<key>,<shell command>
    # See 'zabbix_agentd' directory for examples.
    # Mandatory: no
    # Default:
    # UserParameter=
    # Full path to location of agent modules.
    # To see the default path run command "zabbix_agentd --help".
    # Mandatory: no
    # Default:
    # Module to load at agent startup. Modules are used to extend functionality of the agent.
    # Formats:
    # Mandatory: no
    # Default:
    # LoadModule=
    # How the agent should connect to server or proxy. Used for active checks.
    # Default:
    # TLSConnect=unencrypted
    # What incoming connections to accept.
    # Default:
    # TLSAccept=unencrypted
    # Mandatory: no
    # Default:
    # TLSCAFile=
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    # Mandatory: no
    # Default:
    # Mandatory: no
    # Default:
    # Full pathname of a file containing the agent certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    # Full pathname of a file containing the agent private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
    # Mandatory: no
    # Default:
    # TLSPSKIdentity=
    # Mandatory: no
    # Default:
    # TLSPSKFile=
    # Mandatory: no
    # Default:
    # TLSCipherCert13=
    # Mandatory: no
    # Default:
    # TLSCipherCert=
    # Example:
    # Mandatory: no
    # Default:
    # TLSCipherPSK13=
    # Mandatory: no
    # Default:
    # TLSCipherPSK=
    # Example:
    # Mandatory: no
    # Default:
    # TLSCipherAll13=
    # Mandatory: no
    # Default:
    # TLSCipherAll=
    The server can connect to the proxy. If i telnet to it the connection lasts about 3 seconds then it's closed by the proxy. Same goes for the proxy.
    So first why i don't have the ZBX label green on my hosts? Second, why is the host configuration behaving like that? i have never set any DNS discovery nor anything like that. As you can see the configurations are plain and simple.
    If you have questions please feel free to ask, i'll be glad to provide all the answers.
    Thank you in advance
  • 2G_Storm
    • Nov 2020
    Partially solved. The green label appeared as soon as i added a passive check. But the strange behavior still remains.
