Auto host creation with wrong visible name
  • beast151
    • Dec 2019
    Problem is that after the host discovered, the discovery action rule creates a host with the wrong visible name. ":" is replaced by "_".
    SNMP check gets result HOST::TS::01, but the host is created with the visible name HOST__TS__01. Does anyone know why this happens?
  • tim.mooney
    • Dec 2012
    • 1436
    I'm really curious about your environment. Your hosts literally have :: in their name? And that doesn't break any other software that you're using?
    • beast151
      • Dec 2019
      Literally, hosts don't have :: in their names, but in Zabbix, all hosts named like this Customer::Side::Location.
      In this situation, I take a description, HOST::TS::01, via SNMP from the modem and try to auto-create host in Zabbix.
